The weather is finally letting-up here in Erie PA, so I am back on this thing like hair on a gorilla.
Take a look at the pix and see if anyone sees an issue with my plan for cooling while on the hard.
I want to put in a permanent solution. I had the bright idea to use magnets to hold a plunger to the water inlet on the bottom of the hull... Ummmm, Yeah......
So looking at the pix below I want to put a "T" with a valve on the line I have labeled as line #4
My problem is, I am not really sure line 2 and 3 are both intake lines. I don't understand why I have 2 intake lines to the pump. Are these lines common? What I mean by common is, do they both run the same water? or does one just run the recirculated water and the other run just fresh water? If that is the case I will need to put my “t” on the fresh water side that is harder to get to.
thoughts? I want to crank her up tomorrow. Easter Sunday 2015
Ugh max fiel size 50KB????? Stand by I will be finding a place to park the pic and add A link. I dont want to retype this.....
Here is a link. Hope it works
I removed the link, It was full of spam.. Im very sorry.
