Flax packing size.?
martindesign
Flax packing size.?
Just got my new rudders and getting ready to rebuild the setup. I went with the nylon stuff box style. Do I need 1/4" or 3/16" flax packing on these guys. I think it's quater but wanted to verify. Old ones just used rust.
Catawba Oh
Catawba Oh
Re: Flax packing size.?
Fastjeff's Law of Packing: Always use a smaller size than recommended. It's lots easier to get the rings in, and it doesn't matter in the long run after you tighten it up.
martindesign
Fair enough. 1/4" it is then the gap is 9/32. Thank u sir.
Catawba Oh
Catawba Oh
I used 1/4" on mine this spring. No issues.
As Jeff said, you can use a smaller size and simply put an extra layer or two of material.
Eric Spies
1989 32 SDFB
Lake Lanier, GA
1989 32 SDFB
Lake Lanier, GA
martindesign
Well I installed the new stainless rudders tonight. And used 1/4" palmetto brand graphite coated flax packing. In the product description it says nothing about marine use. Just that it is for seals in pump type applications and it is safe for water use so well see. My only complaint is that it is pretty stiff. I really cranked them down before I got the drip to slow. ( I was pouring water on from top to test since boat is on stands) is there truth that it will swell a bit once in the water?
Catawba Oh
Catawba Oh
If that's a Teflon based produce, they don't really swell, but you can crank 'em down really tight since it's not a prop shaft.
martindesign
My only concern is, how much can those nylon threads take. They are pretty fine.
Catawba Oh
Catawba Oh
I replaced the delron plastic stuffing box gland with a bronze unit. For $89, it was worth the extra expense for the peace of mind. You can buy them at Deep Blue Yacht Supply.
In case your wondering, the plastic unit broke during removal. I was replacing the rudder shaft bearing.
Eric
Eric
Eric Spies
1989 32 SDFB
Lake Lanier, GA
1989 32 SDFB
Lake Lanier, GA
I hope you electrically isolated it from the aluminum hull!
It mounts in a rubber hose. Between the hose and packing material, it is isolated from the hull and rudder.
Eric Spies
1989 32 SDFB
Lake Lanier, GA
1989 32 SDFB
Lake Lanier, GA
