Engine oil
- tundrarules
Re: Engine oil
1985 29 Sedan
Edelbrock 1409 carbs
Mallory distributors
780 hrs/eng
TN River, MM 213.8
780 hrs/eng
TN River, MM 213.8
				nascarjonb
Re: Engine oil
I have twin 1986 360's. I have a friend that swears by Rotella for most applications in his classic cars and his own ford truck daily driver... my question is should I be using that zinc additive aswell with rotella sae 30? also should I use 30 weight or another blend.
							1986 28 fisherman
twin chryser 360's
						twin chryser 360's
Re: Engine oil
YES!   I used Lucas ZDDP additive. Half a can per engine.
"We live at the bottom of an ocean of air, not at the top."  General Marvage Slatington
				nascarjonb
Re: Engine oil
Jeff, do you use rotella deisel oil? That stuff allready has zinc in it.  I'm worried that a additive will be too much with the oil...
							1986 28 fisherman
twin chryser 360's
						twin chryser 360's
Re: Engine oil
I have used Rotella for years with great results. I also add a bottle of Rislone per side at oil change.
Additionally, I add a half dose of Sea Foam at fill up. I don't know if that is overkill, but people comment on how smooth they run.
Scott
Scott
Scott Ross
Thanks Dad
1988 32 Fisherman
Sandusky, Ohio
						Thanks Dad
1988 32 Fisherman
Sandusky, Ohio
Re: Engine oil
Lubricants are dirt cheap compared to rebuilt blocks!
Knowhatimean?
							Knowhatimean?
				nascarjonb
Re: Engine oil
what grade of rotella do you use?thanksdad wrote:I have used Rotella for years with great results. I also add a bottle of Rislone per side at oil change.
Scott
1986 28 fisherman
twin chryser 360's
						twin chryser 360's
Re: Engine oil
There's only one: 15 W 40 (as I recall).
						Re: Engine oil
You can get Rotella in all the popular viscosities. 15w 40 and sae 30 are most popular. Sae 40 gets used in a lot of diesel boats. They may even be offering 20w 50 and 0w 40, but that might be synthetic.
Re: Engine oil
Rotella for me also.
							Jeff Monday (Blue Mondays)
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
