Run Dry blue impellers
Any one have any information on the Globe Run Dry impellers for Sherwood pumps??
Im only getting one season out of a rebuilt pump top to bottom everything new that you can put into the pump.
still have steam (not sure why) but these cost around double what the Siera impellers run and say they can run 15 min out of water and still be ok.
We will see ordered two today.
Jeff Monday (Blue Mondays)
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
Re: Run Dry blue impellers
What part number are for the Sherwoods? Been looking for a cross reference, but no luck. Thinking of making the same modification.
I have read differing reports...will try to find a link
As has been said, impellers are cheap, engines are not
W. J. Brockman
1984 Marinette Express Bridge
Twin 318s 235 hp
Bolles Harbor, Michigan
Twin 318s 235 hp
http://www.globecomposite.com/Marine_Products_Impeller
I have a set for my 1975 318's. I haven't put them in yet, but have seen great results in an old 305 chevy. Not sure if they make them for dual pocket pumps.
I have a service kit that I never used. I'll let it go for $25.00. PM or email me.
I have not had much luck with anything from Sierra.
If you have the D60 Sherwood the Globe run dry number is model 620 p/n 01-12-1460
Lower River rd
Rabbit Hash KY
Lower River rd
Rabbit Hash KY
- tundrarules
Run-Dry impellers for Sherwood 10615K impeller replacement/cross reference. For Sherwood G-7 raw water pumps.
http://www.defender.com/product3.jsp?pa ... &id=141000
Model: 625
Globe Part Number: 01-12-1480
Product Specifications:
Outer Diameter : 2 9/16 inches / 65 mm
Width : 1 5/8 inches / 41 mm
Shaft Size : 5/8 inches / 16 mm
Drive Type : Keyway
Core Type : Composite
Number of Blades : 12
Liquid Type : Water
Gaskets & O-Rings : Yes
Packaging : Clam Shell
Product Notes:
Includes gaskets and/or O-rings.
Model: 625
Drive Type : Keyway
Liquid Type : Water
Product Notes:
1985 29 Sedan
Edelbrock 1409 carbs
Mallory distributors
780 hrs/eng
TN River, MM 213.8
780 hrs/eng
TN River, MM 213.8
Well, took the pumps out this winter and installed the Run-Dry's. We'll see how long they last. The rubber ones dry up & get brittle in a couple years, these should outlast them based on seeing how long the blue synthetic coolant hoses work.
In my opinion the impeller is an annual maintenance item, I always replace once a year even if I put only 50-75 hours on which is a light year for me. It's cheap insurance to install a new impeller every year not to mention you then can check the bearing in the pump for roughness and or play. I've only ever had single engine boats so I might be a little paranoid, I keep an old impeller or two on board just in case...javalin390 wrote:Well, took the pumps out this winter and installed the Run-Dry's. We'll see how long they last. The rubber ones dry up & get brittle in a couple years, these should outlast them based on seeing how long the blue synthetic coolant hoses work.
forest lake, mn
Duluth, mn
Washburn, wi
forest lake, mn
Duluth, mn
Washburn, wi
