Running 318 chryslers in saltwater.
I have a 32' sedan fb, the engines are raw water cooled. Do I need to install a confined cooling system or can I run with the fresh water system, if so what precautions do I need to take?
Re: Running 318 chryslers in saltwater.
bboats wrote:I have a 32' sedan fb, the engines are raw water cooled. Do I need to install a confined cooling system or can I run with the fresh water system, if so what precautions do I need to take?
bboats,
Please add a signature to your posts.
Boating in salt water with raw water cooling not a very good idea. You know salt and cast iron
If it is new to salt water I would defiantly look at installing a closed system. There are a few available on websites. They ant cheap but neither are new engines
They do make flushing kits for raw water cooled engines or you can make your own set up
