Kohler 7.5 forsale for parts Cheap
Posted: Wed Oct 29, 2014 2:28 pm
by Joe
Hello, I have a Kohler model # 7.5 R63 generator.Complete. It is approx 1989 model. The engine is bad. Dont know what happened. Low oil? broken oil pump? Spun bearing. It will turn over. knocks very loud. Metal in oil. Selling it for "parts only" It has closed cooling . 1800 rpm model. If anyone has a need for it. Call me 502 718 8277 Joe. Will let it go cheap. Make Offer. You will have to pick it up. It is at my shop. In Louisville Ky
Re: Kohler 7.5 forsale for parts Cheap
Posted: Fri Nov 14, 2014 6:15 pm
by Joe
Generator is SOLD.
Posted: Sat Nov 15, 2014 10:08 am
by Roger2
While winterizing my boat this fall, I finally learned, by accident, something I've dealt with for 7 years. ( I'm a slow learner) On starting my 7.5 diesel Kohler, the fuel solenoid will sometimes not snap in, especially after sitting a long time. I've been pushing both the start & oil pressure by-pass switches at the same time. I simply use a piece of broom handle to help the solenoid in. Well in doing so this year I looked at the position of broom handle and hit the oil pressure by-pass switch first. guess what it snaps right in! Hit the by-pass first it goes right in every time. The voltage drop of starter load is enough to prevent the solenoid from snapping in!! You guys probably already knew this. I guess with gas generators though, just the ignition is disconnected. Oh well might be helpful to someone.
Roger
