No power to some instruments on dash
nascarjonb
Post by nascarjonb »
Hello fellow BigM Lovers!
I took my first ride in my new to me 1986 marionette 28 sport fisherman with cabin and fly bridge on Sunday. I found out that the depth finder, horn, blower motor, and syncronisor screen were not working. I am a Automotive Technician so Im very familiar with how 12 volt DC works so I tore into the switch panel and I found that there were a few orange wires that feed power to the switch bank. The one orange wire that feeds power to all of those non working electronics does not have any voltage so i must assume i have a open in the circuit. I temporarily jumped from another wire that feeds both bilge pump switches and the lorance GPS. I found that this worked to get everything working for the weekend. I have looked all over this boat and I am unable to find a fuse box. I found one breaker on the fly brige for all of the instruments but it was fine. I cant find wear this wire originates from. on the power distribution panel there are not any orange wires, and also the wire disappears behind the dash to the starboard side.
My question is should I make a permanent jump from that circuit that is working, does anyone know wear I can find this wire originates so i can fix it, or should I run a new wire??
If i should run a new wire wear do they run the wires up to the bridge and should I run from the battery?
1986 28 fisherman
twin chryser 360's
Rob
Re: No power to some instruments on dash
Post by Rob »
Look in the head. The mirror/medicine cabinet might swing open and the fuse box might be there. It was on my older than your model. My head was in front of the helm starboard side.
1973 32' FB Express
Cincinnati, Ohio
Were you able to resolves this issue? I also dock in Marblehead, and am also a mechanic by trade. Let me know, as I am up there getting mine ready for launch soon.
nascarjonb
Jim
I will be at matblehead tonight and I'm going to mess with it in the morning. Are you going to be up all weekend?
1986 28 fisherman
twin chryser 360's
I will be up there most of Saturday putting my engines back together. I dock at Lakevue. Check your private messages under your user name, I will leave my cell number there. Jim
nascarjonb
Thanks for the offer of help but I figured it out. It turns out that what I thought were toggle switches were mis labeled in the engine bay and they are breakers. I discovered this after taking the panel completely apart. I found that one of the mislabeled switches was a 30 amp breaker and had power on one side and non on the other even with the breaker switched on. I jumped power over and found everything came to life!!
I replaced that breaker with a Napa 30 amp push buttons breaker and everything works great.
1986 28 fisherman
twin chryser 360's
Awesome. I've found that some self re-setting breakers, over time, just simply wear out and cannot bring themselves to re-set.
DougDoty
Post by DougDoty »
I have switches beside those breakers in my engine room mounted just above the batteries and and am forever bumping on off and loosing power to stuff and having to go into thinking cap mode :)
"When in doubt, look for a bad ground."
Good advice!
nascarjonb
Thanks for all the advice... I think I am going to replace the whole panel with updated push in breakers and a fresh piece of teak some time this summer... but I have other projects that come first before preventative stuff...
1986 28 fisherman
twin chryser 360's
