360 oil treatment
Posted: Mon May 23, 2016 10:03 am
by shade2u2
Now that my old 360 is broken in (about 1,280 hours - lol), I have what I would describe as suttle "chatter" - mostly at higher RPMs. It uses about 1/2 to 1 qt of oil between oil changes (each season). I have not checked compression. Power seems okay.
Could this be lifters sticking? I was thinking of an additive treatment to see if I can help this. If that seems like a decent 1st step, what additive would be recommended? I run 30 wt Shell Rotello oil.
Also, what zinc additive (or other) would you recommend after I change oil?
Thank you in advance for your help.
Re: 360 oil treatment
Posted: Mon May 23, 2016 2:23 pm
by DougDoty
I have personally seen some stuff from the parts store called " valve medic " loosen or disolve the buildup in some lifters and they returned to normal. ??
Posted: Tue May 24, 2016 5:40 am
I have the solution: Lucas Oil Stabilizer. Added it to my starboard engine and it works brilliantly!
Here's what's happening: The lifters are leaking down on you after sitting (especially if the motor is slow starting up after sitting a while). Add a bottle of this magic stuff and the problem will go away.
PS: If you're not satisfied with this product I'll pay for it! How's that for confidence.
Posted: Tue May 24, 2016 7:00 am
by bcassedy
A better endorsement has never been made! :D
Posted: Tue May 24, 2016 7:27 am
by ericinga
The starboard motor in our 32' had leaky lifters. Start the motor and it sounded like marbles rolling around.
I added 1/2 quart of Marvel's Mystery Oil. After one heat cycle, the lifters now maintain pressure and do not leak down. I'll change the oil after a week or so.
I also added MMO to each cylinder during the wet compression test. I wanted it to soak into the rings and break up any carbon.
Eric
