Robalo220 is dead on. Gate valve is seized up, heat tape on inlet and wrapped with insulation and duct tape. Hope to cut it off, put on a ball valve and check into seeing if I can get a plate welded on. The plate may be tough to get done but I will check into it.
Thanks for the input.
Any idea what this is?
Re: Any idea what this is?
1978 37 Double Cabin
Lake Cumberland KY
Lake Cumberland KY
Legend, glad to hear you've got it figured out. Plate would be great. Good aluminum guy should be able to fix you up. Not cheap but best way to go. You could unscrew the gate valve and replace with the ball valve and leave it shut. But do you really need that thru hull to remain? Glad to be of any help.
Cheers!
Cheers!
454 Crusaders
454 Crusaders
Now that is nice boat.
1991 41' Marquis Convertible
bill wrote:![]()
Now that is nice boat.![]()
Thanks, I got lucky finding one. I need to figure out how to shrink my photos so I can post a pic of it.
454 Crusaders
454 Crusaders
