Wiring diagram
Wiring diagram
Here's a long shot, wishful thinking question. Any chance there's a wiring diagram for my 1962 Marinette? My wiring is a train wreck. I know an ohm from a volt and I'm not afraid to totally rewire if need be. I'm just looking at all of the splices, considering everything that doesn't work and wondering what my options are.
1962 Marinette 31' Express
Single Gray Marine AMC 327
Mercury 500
1976 Saquaro Jet Boat
Ford 460
Mercury 500
Ford 460
Re: Wiring diagram
We know it is a 1962 Marinette.
What length
How many engines
Where is your signature
Re: Wiring diagram
Sorry, got ahead of myself. It's a 30 ft single engine 327 AMC. Guess I need to look into signature. Not sure what I need to do? I have the Gray Marine shop manual, which is very helpful. It runs awesome. Not charging so I'm replacing the generator and regulator with a single wire alternator this weekend. It would be nice to see a wiring diagram to have an idea if available.
Mercury 500
Ford 460
Mercury 500
Ford 460
Re: Wiring diagram
All I have on my PC is the old Mopar engine manual, but I can tell you this much: The new alternator requires only a "hot" wire to the battery. The hot wires to your present generator regulator needs to be tapped off.
Re: Wiring diagram
Thanks Jeff. Yes, I bought a 1 wire alternator. Fortunately I have tbe Gray Marine engine manual for the AMC which will help me identify some of the engine wiring. What I'm looking for is a wiring diagram for the rest of the boat.Fastjeff wrote:All I have on my PC is the old Mopar engine manual, but I can tell you this much: The new alternator requires only a "hot" wire to the battery. The hot wires to your present generator regulator needs to be tapped off.
Mercury 500
Ford 460
Mercury 500
Ford 460
Re: Wiring diagram
Good luck with that!
Re: Wiring diagram
Oh well, I was hoping. Put the 1 wire alternator on this weekend. At least she's charging now. I'm just going to start building a wiring harness one circuit at a time. I've never seen anything like it.Fastjeff wrote:Good luck with that!
Mercury 500
Ford 460
Mercury 500
Ford 460
Re: Wiring diagram
Don't envy you that nightmare! I hate electrical wiring.
