With the warm winter we had in the Cincy area, I worked on the boat a bit. One thing I did was to fill the gas tanks and add Sea Foam to prevent the gas from becoming unusable (something I've done for several years). NOTE - I also treated to gas that was in the tanks at the end of the season with Sea Foam to stabilize the gas for this year's usage.
As I'd had both knees replaced in late '16, my mobility wasn't where it needed to be so I enlisted the help of one of my sons. Unfortunately the gas cap on one side was left off after treating with Sea Foam and then topping off the tanks (guarantees a good mix). We've had rain over the last 6 - 8 weeks so my concern is the possibility of water getting into the tank. I don't shrink wrap (just cover the cockpit with a tarp), so any rain would've run down the gangway and possibly gotten into the tank as it splashed up against the fill fitting.
I'm looking for suggestions on how to handle this....
Some of my thoughts...
1. Disconnect the fuel line at the input side of the cartridge fuel/water separator, connect a manual pump ( https://shop.advanceautoparts.com/p/per ... fragment-4 ) and see what I pull from the tank into a glass jug.
--> If water present, pump until no water shows up (as pickup tube ends w/n 1" of bottom this should remove a significant amount of water.
2. Treat tank with Sea Foam or ??? to remove the remaining water.
3. Take the above mentioned pump and snake the intake into the fill tube (with a weight attached to ensure hose rests at bottom of tank) and see what I can pump out....
--> crud / water - keep at it until get no crud/no water.
4. Pull the sender unit out, drop the weighted hose to the bottom of the tank, and pump out in that manner.
5. Listen to what someone else has done.
I'm not worried about what's in the gas lines att as they contain the treated gas from last fall. However, with the open fill fitting and the rain that MAY have gotten into the tank, I'm a little concerned about firing up the engine, even with the standard new fuel/water separator that'll be in place. Comments / suggestions?
