NEWMAR
https://dcpoweronboard.com/galvanic-isolators/
Galvanic Isolators
Here is a means to significant savings in boat haul-out fees and zinc replacement costs.
Sacrificial zincs corrode away as they protect metal thru-hulls, shafts and props from damaging electrolysis. Stray, low-voltage current flowing between the AC safety ground and DC bonding system is a principal cause of this "galvanic" action.
Install a Galvanic Isolator between the AC safety ground and DC bonding system to block a majority of the low voltage currents and corrosive action on the zincs. Such current flow and corrosion activity is significantly reduced while the integrity of the critical safety ground path is maintained.
For additional safety, these units feature a large capacitor, providing a secondary low impedance path for sending AC current to ground.
Shore Power VAC, Hz Rated - 115/230, 50-60.
Select these isolators by Amp rating - either 30A or 50A.
Mfg. No. Shore Power
Amp Rating Dimensions
Height x Width x Depth Weight
GI-30 30 2.7" x 4.8" x 7.3"
(69 x 122 x 185mm) 2.45 Lbs
(1.1 kg)
GI-50 50 4.5" x 4.7" x 8.9"
(114 x 119 x 226mm) 3.2 Lbs
(1.5 kg)
SKU Model QTY
00017448 Mfg# GI-30 Price: $168.00
00017445 Mfg# GI-50 Price: $198.40
View Cart
